Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do I redo this pin connector?
Old 01-29-2013, 07:09 AM
timothale timothale is offline
Wiki Edits: 27
pin removal
If you can' grab the wire end . sacrifice the Molex tool, Cut off the last 1/2 end and slip the hollow barrel over the pin then use a small drill bit to push it out. If you have access to a lathe you could just make a barrel piece
