How do I reduce current for an Air/Fuel gauge? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2010, 06:51 AM
I have an Air/Fuel gauge and it is hooked up to the oxygen sensor that needs a maximum of 1-volt. Currently the oxygen sensor gets voltage off of the car's computer so it's working fine, (this is the signal wire).
I am planning on disconnecting the ECM so I'll need an alternate source of voltage. Since vehicles runs on a 12-volt sytem, what can I use to reduce the voltage required to run the O2-sensor and gauge?
Old 03-21-2010, 08:04 AM
T-bucket23's Avatar
Wiki Edits: 26
I am planning on disconnecting the ECM so I'll need an alternate source of voltage. Since vehicles runs on a 12-volt system, what can I use to reduce the voltage required to run the O2-sensor and gauge?
Unless it is a heated O2 sensor, it does not get voltage from anywhere. It actually generates the voltage and feeds it to the computer. The O2 is like a battery that uses the exhaust gas for electrolyte, and the Oxygen content controls the output voltage.
Just as a side note, most stock O2 sensors are narrow band and will not work properly with an A/F gauge. Most require a wide band O2 sensor
Chet
Old 03-21-2010, 08:55 AM
Thanks! Now I know how it works.
Well it's not a heated 02 sensor, (the gauge's instructions state that a heated sensor is not nessacary unless one wants instant readings upon vehicle start-up).
As far as a wide band O2 sensor, this gauge is made to function with stock 02's, (it is not meant to be highly accurate).
So, all I have to do is find the signal wire off of the O2 sensor and the gauge should work?
Flexalite fan 180 (tests) brainsboy Engine 5 11-03-2008 05:16 AM
Fan Clutch? 71 c-10 Engine 10 10-06-2008 09:51 AM
Air/Fuel Gauge tuning Mertz Engine 16 04-11-2008 09:19 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Elec. fuel pump relay needed? upstand2 Electrical 4 05-10-2005 05:21 AM
