How do I remove a brake booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2012, 11:09 AM
rusthater89's Avatar
I want to media blast and spray epoxy on my firewall. This is a 1978 Fire Bird.
I removed the master cylinder. I removed the 4 nuts holding the brake booster to the fire wall. When I slid the booster out i noticed a pin on the rod that connects the pedal to the booster. I removed that.
Do I just yank the booster out? I am afraid I might've missed something because I did a bunch of yanking and it hasn't budged. I would hate to break something.
Old 07-27-2012, 08:29 PM
The rod and bolts should be the only thing holding it in..chances are it's probably just stuck.
Old 07-27-2012, 08:42 PM
I think you're right. My light broke the other day, just replaced the bulb. Tommorow I will look again with my light so I won't be feeling around like a blind guy.
Also does the brake booster come apart? The vacuum/plunger unit looks like it can twist apart. It would be nice to check it to see if it is worn out or not.
Funny, I worked two years in a dealership. I did lots of brake work but never replaced a brake booster.
Old 07-29-2012, 07:50 PM
I wouldn't take it apart.. Pretty sure it's a sealed unit. Only real way to tell if they're worn out is if they leak vacuum..
Old 07-30-2012, 07:20 AM
I got the booster out. Turns out the link was a bit bent.
Far as testing the booster. Would I do something like use a mity vac pump, you know the ones that go with the brake bleeder kit?
Old 07-30-2012, 08:09 PM
Brake booster have a large spring inside. The rebuilders have a fixture that they use to disassemble and assemble them.It's near impossible to get one back together right without the fixture.
Old 07-30-2012, 08:14 PM
Thanks, judging from the edges it did look like it could twist off. Obviously why I was asking.
Brake Booster LBL Suspension - Brakes - Steering 36 05-07-2012 09:59 AM
Brake booster? bigj7698 Engine 1 03-25-2012 07:34 PM
brake booster mafiacustomz Suspension - Brakes - Steering 3 07-23-2011 08:56 PM
67 brake booster help my52 Suspension - Brakes - Steering 3 03-01-2009 12:10 AM
S10 Power Brake Booster. Want to remove S10 Racer Suspension - Brakes - Steering 3 03-09-2008 08:43 PM
