Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how do I remove this bushing on a T-350
Old 08-07-2012, 08:18 PM
rusthater89's Avatar
rusthater89 rusthater89 is offline
Originally Posted by Ripper 410 View Post
go to autozone and rent a bearing and bushing driver set if you don't have a seal puller use the screwdriver to bend the metal retainer ring on the seal and pry it out
How much is it to rent stuff at autozone? To make sure I understand, I bend the seal with a screw driver and then pry it out with pliers?
