How Do I Remove Crankshaft Pully - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2010, 04:04 PM
Is Any One Out There Familiar With The 1940 Plymouth Engine? I Need Information On How To Remove The Crankshaft Pulley On The Flathead 6 Cyl.
My Car Is A P-10 Four Dr. Sedan.
I Need To Remove The Pulley So I Can Remove The Timing Chain Cover And Replace The Gasket.
Any Help Would Be Greatly Appreciated.
The Auto Nut
Old 07-14-2010, 06:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Auto Nut
You might want to ask over HERE. They cater to the engines like you have- the flat 6 MOPAR was similar for YEARS.
Old 07-14-2010, 07:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
From what I've gathered, the nut is removed from the front of the crank, then a puller can be used (using the two bolt holes in the hub) to remove the unit.
If you have the hand crank-type pulley nut, the socket size is 1-13/16".
Replace the seal while you're at it- they always seem to leak.
Old 07-14-2010, 07:29 PM
techinspector1's Avatar
Wiki Edits: 326
The Auto Nut
You may not even know that there are original and reprint service manuals available for your Plymouth. Here is one source that I have used for decades with good results.....
http://www.faxonautoliterature.com/Search.aspx?c=4463
Old 07-14-2010, 08:26 PM
how do i remove crankshaft pulley
This Ply. has two nuts in front of the crankshaft pulley. The
last nut ( which would be the first one to come off ) has a weird configuration, like it might take a special tool to remove it. I am at a loss as how to proceed.
I hope you can shed some more light on this problem.
Thank you for your help.
The Auto nut
Old 07-14-2010, 08:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Auto nut
If it looks something like a big, funky, short corkscrew, that was used for the hand crank. Here's a photo:
The size of the nut behind the hand crank socket is what you want to find a socket for, then use an impact wrench or breaker bar to remove it.
You need to lock the engine from turning to remove the nut if you use a breaker on it. If it's a stick (which I'm guessing it is), just put it into gear, block the wheels and proceed.
Old 07-14-2010, 08:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the set-up you have isn't like the one above, it's probably similar to:
Old 07-14-2010, 10:43 PM
How to Remove a crankshaft pulley
Thank you colbalt 327;
After I sent my last reply I realised that the odd looking nut
was for a hand crank. The picture you posted is exactly the same as my engine. Thank you for your help!
I will start the job first thing tomorrow.
Thanks again,
Auto Nut
Last edited by 68NovaSS; 08-24-2010 at 11:57 AM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 07-15-2010, 03:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
This 1940 Plymouth is for sale. If you know any one who might be interested call Dan at (503) 617-4645.
Thanks again,
Auto Nut
Glad to help, Dan.
Just a friendly hint- there is a free "Classified" section of this forum for buying and selling cars, parts, et cetera.
Please click on the Classified icon at the very top of any page and on the page that comes up, click the "Place an Ad" icon and proceed from there. The management will appreciate it, advertising on the open forum isn't allowed.
Good luck.
Old 07-15-2010, 08:34 AM
How to remove a crankshaft pulley
Glad to help, Dan.
Good luck.
Thanks Colbalt 327;
I had forgotten about that.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Using a Grinder to remove paint duallybuster Body - Exterior 16 07-30-2006 10:17 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
How to remove a power steering pully? Skipr Engine 6 05-25-2006 10:58 PM
