How do I remove inner door handles 40 ford pu - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2012, 04:42 PM
Trying to figure out how to disassemble my inner door mechanisms on my 1940 ford pickup.it actually has a 46 cab but apparently they are the same.
Would appreciate any pointers.
Old 08-15-2012, 08:12 AM
eric302's Avatar
Why be normal?
If you're trying to pull the inner door handles off it could be like the inner door handles on my 51 Chev. There are U shaped clips behind the handle that keep the handle on the spline that is connected to the mechanism. There is a U shaped tool that gets inserted between the back of the handle and the door panel. This is used to push the clip off of the slot in the handle. In the past I have used a piece of mig welding wire with a small hook bent on the end to pull the clip off. Hope this helps.
Old 08-15-2012, 08:14 AM
boatbob2
door handles
On my 48 Ford Coupe,there is a pin thru handle and mechanism,use a small punch to remove.
Old 08-15-2012, 08:31 AM
eric302's Avatar
Why be normal?
I didn't know Ford did that. Thanks Bob.
Old 08-16-2012, 05:34 PM
they are held on by pins through them.
Thanks Bob and Eric for your help.
40 Ford door lock; screw broken off, remove housing? 40 Flier Body - Exterior 3 10-13-2011 10:44 PM
Door handles replace 29 ford 2 door Steve Vento General Rodding Tech 4 06-08-2007 04:07 PM
New Old Stock Door handles,locks.inside handles 32chevy vett Hotrodders' Lounge 1 03-22-2007 06:45 PM
Interior Door Handles for 36 Ford joeford Interior 1 02-28-2006 09:29 PM
33/34 ford door handles red34ford Body - Exterior 2 08-10-2003 11:34 AM
