How do I remove left power window mtr in '97 Chev pickup door?
I am not sure if this is the correct place to ask this question, but if not then maybe someone will redirect me.
The truck is a 1997 Chevy 2 door Silverado.
Power window on the left side quit working and the window is up all the way.
I am getting voltage at the motor, so I assume it needs a new motor.
My problem is getting to the motor.
I have removed everything inside the door face and now I am at the inner steel panel (that the motor is riveted to). I removed the dozen or so screws and the panel is loose but it will not come off.
The problem is of course the window arm is still in it's track and the window is in the up position.
How can I lower the glass so that the panel/motor can be removed?
Thanks for any help someone can send my way.........pg
