Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do I remove left power window mtr in '97 Chev pickup door?
Old 07-24-2008, 10:43 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Let's try Autzone's link directly.
First of all, you will have to look at the 5th digit of your VIN in order to determine if it is a "C/K" series or "R/V" series.
(I thought they were ALL "C/K" in 1997, but I see these instructions cover 1988 to 1998 trucks.)
If the link doesn't work, here is the text:
REMOVAL & INSTALLATION
R/V Series
Raise the glass to the full up position and tape it to the door frame with fabric tape.
Disconnect the negative battery cable.
Remove the door trim panel.
Remove the window control bolts and lay the control aside for access.
Remove the regulator-to-door panel attaching bolts.
Disconnect the harness from the regulator.
Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
A notch is provided in the sash panel to allow disengagement of the forward roller on the window regulator.
Remove the regulator assembly through the access hole in the door.
CAUTION
The next step must be performed when the regulator is removed from the door. The regulator lift arms are under tension from the counterbalance spring and can cause serious injury if the motor is removed without locking the sector gear in position.
Drill a hole through the regulator sector gear and back plate. DO NOT drill a hole closer than 1/2 in. (13mm) to the edge of the sector gear or back plate. Install a pan head sheet metal tapping screw (No. 10-123/4 in.) in the drilled hole to lock the sector gear in position.
Remove the motor-to-regulator attaching screws and remove the motor from the regulator.
To install:
Prior to installation, lubricate the motor drive gear and regulator sector teeth.
Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the retaining screws.
Remove the screw locking the sector gear in the fixed position.
Reposition the motor in the door and install the wiring connector.
Attach the regulator to the door.
C/K Series
Disconnect the battery ground cable.
Remove the water deflector by peeling it back.
Disconnect the door lock rods at the module.
Loosen the upper run channel bolt.
Move the run channel away from the glass.
Pull the wiring harness towards the door to reach the connector. Remove the boot from the wiring and disconnect the harness at the door hinge pillar.
Remove the module and window assembly from the door frame by tilting it and lowering it from the door.
Fold back the tab on the channel and slide the glass out.
On trucks with power components, drill out the rivets from the inner handle housing.
Drill out the regulator assembly rivets.
Remove the regulator/motor assembly.
CAUTION
Install a pan head sheet metal tapping screw through the sector gear and backing plate in the hole provided, to lock the sector gear in position.
Drill out the motor-to-regulator attaching rivets and remove the motor from the regulator.
To install:
Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the replacement attaching bolts and nuts.
Reposition the motor/regulator in the door and install the wiring connector.
Slide the glass out into the channel and fold over the tab.
Fit the glass into the rear channel in the door, then, while pulling the channel towards the glass, fit the glass into the front run channel.
Install the boot from the wiring and connect the harness at the door hinge pillar.
Install the lower run channel bolt.
Install the door lock rods at the module.
Install the module panel screws, starting at the top left, then the top right.
Install the water deflector.
Tighten the upper run channel bolt.
Install the trim panel on the door.
