How do i remove the main conection on a 4L60e? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2011, 03:01 AM
old yukon's Avatar
Trying to remove this coonection(see below), but cant see or better feel where the loccking clip is. how do i remove this connection on the passangers side of the 4l60e.
Man there is no room around this thing especially for BIG hands.
Good tranny techs must have either a great range of tools and/or small hands
Name:	main transmission connection on 4L60e.jpg
Old 01-06-2011, 03:38 AM
SSedan64's Avatar
I think one of Crosely's posts had tips for removal, can't remember which one tho'.
Old 01-06-2011, 11:43 AM
tnsmith10's Avatar
when will it rain???
squeeze the sides of the connecter together and lift straight up. there is no clip or locking tab. its built into the connecter.
if you reach up from the side of the case and at the base of the connecter and push both sides in, it will come right out.
The Following User Says Thank You to tnsmith10 For This Useful Post:
V8Truck (08-10-2013)
Old 01-06-2011, 12:21 PM
old yukon's Avatar
thanks for the advice
that makes things easy
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 07:22 PM
Power Steering line conection problems. al37ford Suspension - Brakes - Steering 1 04-29-2006 11:48 PM
2-bolt main vs. 4-bolt main chevy hause Engine 5 10-26-2005 02:37 PM
Anything to remove ATF? 87442lover Hotrodders' Lounge 8 06-19-2004 01:38 AM
What main cap girdle would you recommend for a chev 400 with a 2 bolt main stonedchihuahua Engine 19 01-05-2003 06:31 AM
