How do I remove this mirror from my door? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2012, 07:11 PM
rusthater89's Avatar
It's the drivers door for my 78 Firebird. I can't figure out how to detach the cable switch from the housing that goes on the door panel.
ID:	68975   Click image for larger version
Old 11-05-2012, 07:17 PM
novafreek6872's Avatar
Nova Guru
couldnt resist...sorry...
The Following User Says Thank You to novafreek6872 For This Useful Post:
69 widetrack (11-08-2012)
Old 11-05-2012, 07:19 PM
Last journal entry: was hoping for better than this
there is a tiny allen screw in the innderdoor panel trim piece that the joystick feeds through
you'll see it on the backside of that chrome trim plate.. near the joystick ball..
poncho62's Avatar
Wiki Edits: 5
Isnt there a set screw on the underside that goes in sideways?
Old 11-05-2012, 07:22 PM
Really? I must have overlooked it then. I'll look again tommorow and see.
Old 11-08-2012, 03:28 PM
chevymike's Avatar
A set I had one time had a wire clip that clipped into two holes in the square trim housing. You unclipped it and the joystick barrel slid out and fits through the hole in the door. Knowing GM, they likely changed things over the years to keep ya guessing.
Old 11-08-2012, 04:12 PM
Faith - Respect - Trust
[QUOTE=novafreek6872;1607626]
That was excellent Andy...I had a good laugh...my wife's not home but she's got this one particular pole at the local mall that was built just for that purpose and she could tell you where it is...come to think of it, it may not work for everybody but I do know it's worked for her twice.
Thanks Andy
Ray
Old 11-08-2012, 04:56 PM
Yep your right. That is what it is.
I actually just got done with it and was gonna post but you beat me to it. I was looking at it and was wondering what the wire clip was that was just kind of hanging there. I mean it must serve some purpose little did I know it was actually holding it in. I didn't want to break it but figured if I did I would just have to replace it and just yanked the wire off and it came apart.
How do I remove inner door handles 40 ford pu ford pickup guy Body - Exterior 4 08-16-2012 06:34 PM
How can I remove 2 door post trim from the post and door frame? 1964 Oldsmobile 442 Body - Exterior 1 07-17-2011 05:41 PM
How do you remove the door info tag without destroying it? onebadmerc Body - Exterior 7 11-02-2009 08:05 AM
how to remove door glass 62galaxiguy Body - Exterior 1 07-18-2004 02:13 AM
camaro rear view mirror on door -remote bullheimer Interior 2 01-26-2003 10:19 AM
