-   -   How do I remove Mustang ii Control Arm Bushing? (http://www.hotrodders.com/forum/how-do-i-remove-mustang-ii-control-arm-bushing-221356.html)
Big_Willy 07-06-2012 05:53 AM
How do I remove Mustang II Control Arm Bushing?
This is the upper control arm from a 75 mustang ii. I can see these bushings were pressed in from the outsides over the shaft. Anyone know how to remove these bushings?
http://images5a.snapfish.com/2323232...78532%3Cnu0mrj
Big_Willy 07-06-2012 06:53 AM
Big_Willy 07-06-2012 07:01 AM
Sorry, I posted this in the wrong section. I would delete it but, I don't know how.
Sorry Again
Willy
1957plymouthhemi 07-06-2012 07:02 AM
Normally I clamp them into a vice and then work the bushing out using an air chisel with a rather dull chisel end. You can do the same thing with a hammer and chisel just a little more work.
The factory lower control arm bushings are a bit more complicated as they usually have 2 small tack welds that you normally have to cut with a small cut off wheel before you drive them out.
On the bright side it looks like you got the hard part done......getting the rivets out to get the upper ball joint out :thumbup:
dinger 07-06-2012 07:41 AM
I will move it, no problem. :D
Mojo56 07-06-2012 08:07 AM
A little heat goes a long way...
Cape Cod Bob 07-06-2012 05:31 PM
I need to do this to my original Pinto front end. I don't know why , just old and I think it will be a little quieter.
So, please keep adding questions and pics.
Whose kit are you useing or are you getting all at NAPA ?
Big_Willy 07-09-2012 03:03 AM
Thanks Guys. I used a hammer and chisel....worked great. I already purchased bushings. Found a set on Ebay.
Willy
