How do I remove Mustang ii Control Arm Bushing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2012, 05:53 AM
How do I remove Mustang II Control Arm Bushing?
This is the upper control arm from a 75 mustang ii. I can see these bushings were pressed in from the outsides over the shaft. Anyone know how to remove these bushings?
Old 07-06-2012, 06:53 AM
Old 07-06-2012, 07:01 AM
Sorry, I posted this in the wrong section. I would delete it but, I don't know how.
Sorry Again
Willy
Old 07-06-2012, 07:02 AM
Last journal entry: A few ongoing projects
Normally I clamp them into a vice and then work the bushing out using an air chisel with a rather dull chisel end. You can do the same thing with a hammer and chisel just a little more work.
The factory lower control arm bushings are a bit more complicated as they usually have 2 small tack welds that you normally have to cut with a small cut off wheel before you drive them out.
On the bright side it looks like you got the hard part done......getting the rivets out to get the upper ball joint out
Old 07-06-2012, 07:41 AM
dinger's Avatar
I will move it, no problem.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 07-06-2012, 08:07 AM
Hot Rod Has Been
A little heat goes a long way...
Old 07-06-2012, 05:31 PM
Cape Cod Bob's Avatar
I need to do this to my original Pinto front end. I don't know why , just old and I think it will be a little quieter.
So, please keep adding questions and pics.
Whose kit are you useing or are you getting all at NAPA ?
Old 07-09-2012, 03:03 AM
Thanks Guys. I used a hammer and chisel....worked great. I already purchased bushings. Found a set on Ebay.
Willy
upper control arm bushing helrazr3 Suspension - Brakes - Steering 9 05-23-2007 09:58 PM
up-lwr control arm bushing Jim Cball Suspension - Brakes - Steering 5 11-08-2005 01:40 PM
Control Arm bushing replacement bonuts Suspension - Brakes - Steering 7 03-14-2005 08:06 AM
rear upper control arm bushing removal 68chevelle_ss Transmission - Rearend 18 02-06-2005 02:51 AM
