How do I remove Rhino Lining? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2009, 02:57 PM
cyclopsblown34's Avatar
Colorsanding painter
The original owner of my truck had everything from the top of the bumpers down sprayed with Rhino Lining. How do i remove it? My buddy who owns the local Rhino lining company said to cut it into one inch wide strips and peel it off the truck. It is supposedly a messy slow process.
Old 03-12-2009, 03:13 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I do not envy you that job at all..yup cut thru the liner with a sharp utility knife and then a sharp chisel will scrape the strips off..sorry for the scratches in the metal which I know you will have..a 36 grit disk to get the last little bits off..this is the only way I know to deal with that stuff..
Sam
Old 03-12-2009, 03:18 PM
I guess Gooney wasn't feeding me full of Bovine Scatology (BS) then. My only other option is to leave it and paint over it. At least it's a little truck.
Old 03-12-2009, 03:34 PM
Wiki Edits: 3
It will look like gravel guard when painted over..wish I knew another way..Nice truck..
Sam
Old 03-12-2009, 03:38 PM
Thanks, I was thinking it would look like gravel/rock guard if I painted it. That might be the ticket with how busy I'm getting in my shop. I have to come to work to get a break. Not complaining one iota, just making a statement.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 07:07 PM
Painting Rhino Lining - And a Couple Other Questions S10 Racer Body - Exterior 2 06-25-2008 08:58 PM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 08:50 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
C6 Installation Trucknut Transmission - Rearend 6 01-18-2006 06:01 AM
