How do I switch from a generator to an alternator? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2005, 06:15 PM
I'm rebuilding my 56 Chevy 210, installing a 350 small-block, and want to upgrade to an alternator (standard chevy stuff, not a 1-wire unless I need to). All the original wiring is still in place, including the wiring from the original generator. I don't plan on adding any additional electronic gadgets (don't even have a radio). What do I need to change to run an alternator - what wiring changes need to be made? Any help is appreciated - thanks.
Old 12-14-2005, 06:36 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Well as long as your current factory wiring is in good shape I don't see a need to change much. A 1 wire alt is the only way to go on this IMO.just mount it run a 8ga fused wire to the battery and forget it. You can a regular 10si alt on it. Run a fused 8ga wire to the back of the alt. put the larger of the 2 wires from the regulator to switched ign. or full power from the back post on the alt. The little wire is the bulb wire, you can use a bulb from the dash if there is one or just wire one in. But the 1 wire alt is the better choice.
Old 12-14-2005, 07:32 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
You don,t say what year your 350ci is from, so I'll give both internal and external regulator setups.
You will be glad if go with a the GM (1)- wire (internal regulator) alternator. It's the easy way.
You will need to identify the BAT. wire in your existing '56 harness. This is the heavy guage #12 wire. This will connect to the alternator stud.
If you are using a (1)- wire alternator, this is the only connection you need to make. Tape up or remove the '56 Armature and Field wires. You will not need them.
But if you have a external regulator, You need (3) wires from the alternator to the regulator. (1) #12 wire from the alternator stud to the regulator. And (2) #16 wires from the alternator to the regulator connected to the terminals as identified on the your setup.
Replace your '56 ammeter with a voltmeter and connect it to any ignition switched source.
vicrod
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
Remote Shut Off Switch doesn't shut it off! F-1Rodder Electrical 2 05-01-2003 04:01 PM
Alternator Switch dollybud Electrical 5 10-06-2002 04:50 AM
