Generally all you have to do is remove the four bolts and nuts from the rear end yoke and push the driveshaft forward about an inch to remove it. I'm not familiar with your year Chevy but if it has a one piece driveshaft that's how you do it. If it has a two piece shaft with a center "U" joint you may have to remove the center "U" joint mount to get the shaft out.
