How do i take off my driveshaft?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2006, 08:26 PM
aztek_warrior's Avatar
I had a question about how to take off a driveshaft
on a 1963 Impala 4dr sedan. If anyone could help
me throught it...i would greatly appreciated....
Im planning on dropping my tranny to get it rebuild,
but can't seem to disengage the front yoke from the
tranny, is there bolts holding it in or springs i need to
take off..Also whats the easiest way to drop the tranny.
Thanks for any info you can provide...
Also tranny is a powerglide if it makes a difference.
Old 05-08-2006, 10:18 PM
Wiki Edits: 49
Generally all you have to do is remove the four bolts and nuts from the rear end yoke and push the driveshaft forward about an inch to remove it. I'm not familiar with your year Chevy but if it has a one piece driveshaft that's how you do it. If it has a two piece shaft with a center "U" joint you may have to remove the center "U" joint mount to get the shaft out.
Old 05-08-2006, 10:50 PM
tbirdscott's Avatar
stuff'n things'n whatnot
the yoke should pull right out of the trans
Old 05-09-2006, 12:07 AM
WAIT!!! There's a driveshaft support bearing that has to be unbolted first. Look at your car's frame. It looks like a big X. Look at the middle of the big X, and see the two bolts on the bottom. Unbolt them, and then you can slide the 2-piece driveshaft, complete with support bearing, out toward the rear.
This is true for '58-'64 Chevy passenger cars.
Old 05-09-2006, 07:52 PM
Thanks for the help, i got the driveshaft off
now its just removing the tranny which, i'll
probably do this weekend.
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 01:01 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 10:20 PM
short driveshaft high angle ujoints powerrodsmike Suspension - Brakes - Steering 16 02-09-2005 08:58 AM
Driveshaft measurement 71gtx Transmission - Rearend 6 01-11-2004 12:00 PM
newer driveshaft for my s-10 catscan4free Transmission - Rearend 0 01-10-2004 03:51 PM
