how do i tell a real 302 from whatever - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 09:41 PM
Old 02-02-2012, 09:48 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Define "real 302"?
Define "whatever"?
Assuming Ford 302 ...
versus 5.0L?
versus 260, 289, 351W?
versus versus Boss 302?
Not quite sure what you're asking ...
Old 02-02-2012, 09:57 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Originally Posted by 66GMC
Define "real 302"?
Define "whatever"?
versus 5.0L?
Don't forget the Chevy 302
Old 02-05-2012, 08:20 AM
66GMC's Avatar
Yep, that's why I said "Assuming FORD 302"
If it's a question of 302/351W identification, there was a recent thread on this that I remember reading. Simple, quick, and accurate. It had to do with deck height and the height of the "China Wall" at the front of the intake manifold, I think.
Here is the thread
Originally Posted by willowbilly3
I always tell my Chevy buddys that anyone can wrench on a chevy but it takes a real mechanic to work on a Ford,lol.
I know you already have the intake off but the simplest way for me to tell the difference is the lower thermostat housing bolt. On a 221-302 is will be somewhat behind the timing cover and you can't get a socket on it. On the 351W the same bolt is high enough that you can remove it with a socket and extension right over the top of the timing cover/water pump.
Originally Posted by Joe G
Here is how you can tell a 302 from a 351 block from 10 feet away:
On the front of the engine, look at the distance between the top of the water pump and the deck.
On a 302, the top of the water pump is about even with the deck of the block, but on a 351, the deck is over an inch taller at that point.
If it's a 302 vs 5.0L situation ... there are quite a few differences when it comes to balancers, timing covers, w/p rotation, and accessory drives.
Is this for real screamin340 Hotrodders' Lounge 6 04-28-2004 10:18 PM
Is this guy for real cheezbay Hotrodders' Lounge 11 04-02-2004 06:34 PM
560/15's REAL pics of REAL Car! DragLinkscc Hotrodders' Lounge 7 10-21-2002 05:54 PM
for real, my sit is really up. hot_rod_kid Hotrodders' Lounge 16 09-08-2002 12:41 PM
is it real hogerdoger Hotrodders' Lounge 2 03-21-2002 03:47 AM
