8.8 rear end
If your lucky it came with an 8.8" rear end.. There actually decently strong. if your just putting a mild street v8 in it should be fine. Will handle 300 hp easy.. then the 28 spline axles and differential can be a problem if you gonna go nutz on power.. Some F150's have came with 8.8 rears in them. Hmm you can tell from the rear cover.. looking at the back cover it will mostly rounded out on the left area where it comes out in a semi circle.. the othe axle that could be in you ranger I think is a 7.5" rear end.. It will be more rectangular looking with a distinct rectangular shape to the semicircle part sticking out on the cover.. the 7.5 will only handle about 200 hp and a 5.0 or 5.8 would tear it to shreads with a mild build.. also the sides of a 7.5 cover are perfectly rounded VS. a 8.8 has a straight part on the sides.. almost octagon looking cover outline with the 8.8.. altho the ranger 8.8 might be different from the mustang 8.8.. you might have to upgrade the rear end a bit.. mine is.. I have an 8.8 rear in my ranger with about 300 horse 302 in it.. it took all the beaten I could apply with a 5spd and a good clutch + 11 inch wide tread BFG t/a's
well many rangers came with limited slip~prolly the correct term instead of posi.. The differential in rangers might be a weakpoint.. mine has an aftermarket locker in it.. and I will again mention the beating it has handled.. my truck would start out in 3rd with out much trouble when I wasn;t paying much attention... thats alot of torque...
| I need some input on putting a Ford rearend under a 1972 Dodge Dart | onebadmerc | Transmission - Rearend | 7 | 12-21-2005 10:30 PM |
| Hotrodders Knowledge Base: Transmission - Rearend | Jon | Transmission - Rearend | 0 | 11-26-2005 06:23 PM |
| my buick/86 camaro posi rearend | daddyrain | Transmission - Rearend | 2 | 11-06-2004 12:51 PM |
| Torque on the rearend | meschnebly | Transmission - Rearend | 6 | 09-03-2004 02:19 PM |
| Ford Rearend | 00stang | Transmission - Rearend | 5 | 08-25-2002 04:12 AM |
