How do I tell what starter to get? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2010, 08:20 AM
I'm doing a engine swap in a truck from a v6 to a 305 that had a turbo 400 transmission and we got the old flywheel off the v6 but forgot to get the starter since the guy we were selling the old v6 to was there as we were pulling it.
So I was wondering can I just count the teeth on the flywheel and then go down to like pep boys or something similar and get a starter based off that? Or maybe just tell them the kind of transmission? Since everything is sitting in there right now, but I could pull the transmission and look at the torque converter if I need to. Thanks.
Old 06-19-2010, 03:28 PM
T-bucket23's Avatar
Wiki Edits: 26
The starter needs to match the flywheel. If it is still out get the part # off the flywheel and look it up. It will tell you how many teeth it is.
Chet
Old 06-19-2010, 06:16 PM
Which starter? Good question.
As you know, the starter drive gear must match the flex-plate ring gear.
The 14.130" OD flex plates have 168 teeth and use a starter with offset starter bolts.
The 12.750" OD flex plates have 153 teeth and use a starter with in-line starter bolts.
Note: Most SB Chevy engines will have both starter bolt patterns and can use either starter if the appropriate flex plate is used.
Pre-1986 crank to flex-plate bolt pattern is 3.580" OD and s found on a crank with a 2-piece rear main seal.
1986-up crank to flex-plate bolt pattern is 3.000" OD and is found on a crank with a 1-piece rear main seal.
The 1986 engines could have either a 1-piece or a 2-piece rear main seal. The torque converter bolt pattern could be either 10.750" OD or 11.000" OD depending on which automatic transmission the flex plate was attached to. The torque converter I used in my 1991 S10 Blazer 4.3L V6 was a Pioneer 871006 with 168 teeth and had both torque converter bolt patterns.
Hope this helps a little.
Old 06-21-2010, 09:57 PM
Thanks for the info! Actually that info helped a lot I simply just went down to NAPA and picked up a starter from a 90' C3500 that had offset starter bolts and went with a sbc and it works like a charm with the flex plate that was originally on my th400. So thanks for the help! Plus that was a lot easier then replacing the flex plate.
Another Chevy Starter Issue (pic) Bluecollarron Engine 15 10-08-2013 12:12 AM
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 03:41 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 03:44 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 09:07 PM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 06:48 PM
