how do i test 61 generator - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2004, 07:43 PM
have a 61 bel-air and no juice to charge battery nothing off the generator on both terminals but is it the gen or the regulator test for power staight off the gen but maybe the field is not hooked up right to the regulator swaped and not change any help would be nice.
Old 09-01-2004, 06:24 AM
willowbilly3's Avatar
Last journal entry: Body mods
A quick field test for a delco generator. Un hook the wires (and the belt if it is on the car) Hook jumpers to a decent battery, connect other end to the gen, negative to the case and positive to the positive gen post. It should turn on it's own like a motor. Not real strong like you could run anything off it but it should get spinning pretty good.
Another test is to just ground out the field wire. It should put out full at that point. I guess you would need a volt meter to see but you should be able to hear it pull with a good ear. Never rev up an engine with an alt/gen full fielded, you might let the smoke out of something.
