Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how do i use the 6 volt gauges on a 12 volt system
Old 07-26-2003, 01:06 PM
Jag Daddy's Avatar
Jag Daddy Jag Daddy is offline
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
You might want to look into an electronic regulator. they are not to tough to wire for gauges and small stuff BUT anything with high current loads will need more brute force i.e. BIG resistors.
I'll look in my curcuits and see what I have for a 12 to 6 volt regulator. One thing if you use and electronic regulator your voltage will be very stable, the resistor curcuit will fluxuate with the input voltage. There is also a thing called a Voltage divider circuit that is a little more complicated to wire for each gauge but it will work too. If your interested I'll calculate one up
Regards
Mark
