I used this diagram on installing my airconditioner, Might help you out as well.
http://www.vintageair.com/DownloadsS...%20Diagram.pdf |
Kirk,
I was looking at the wiring diagram for your radiator fans on the Be-Cool website. Because you have a trinary switch, the AC relay setup they show in their diagram is unnecessary. Using a trinary switch can improve system performance, extend the life of the radiator fan, and in this case simplify the wiring substantially. In your case, all you need to do to hook-up the trinary switch is this: Assuming all is wired according to the manufacturers diagram EXCEPT for the AC relay and related wiring. Follow the manufacturers dual fan non-AC wiring diagram. The two blue wires on the trinary switch are the fan switch. Connect one of them to ground, and connect the other either directly to the temp switch, or splice it into one of the gray temp sensor wires. (yours should be gray) Then hook-up the trinary switch's other tho wires (the compressor switch) as shown in the diagram that kleen56 linked to. For reference, here is a diagram of how I wire electric radiator fans: ![]() Hope this helps. Joe G. Last edited by Joe G; 01-13-2009 at 01:27 AM. |
Sometimes the temp switch is in the control panel, other times it's mounted to the side of the evaporator case. Good luck. Joe G. |
If you have a themostat attached to the AC unit under the dash, the hi/low pressure wires will connect between the AC t-stat and the compressor.
If you are not sure where the t-stat is----could also just tie it to the existing AC clutch signal wire. |
Thank you guys, When I get home tonight I will begin to relate this info to my system. It is more than likely really easy once I understand it. Right now I feel like this
Thanks Kirk |
Joe
Following your diagram: one blue wire going to the temp sensor, and the 2nd blue wire going to the ground. Kleen56 shows one black/green wire going to the clutch, and the 2nd black/green wire going to the 86 pin on the relay. Is this right? On my relay they do not have the pins numbered. 86 should be what wire. According to your post I should remove the 3rd relay and wire into ONE of the remaining relays. Is this right. Thank you for the help Kirk |
Just to review, wire the radiator fans exactly as shown on the Be-Cool website for a non-air conditioned application. Then take one of the two blue wires on the trinary switch and connect it to your temp switch (on the radiator or engine - wherever it is), and connect the other blue wire on the trinary switch to ground. The Black/green wires on the trinary switch are the cycling switch for the compressor clutch. One of them goes directly to the A/C clutch, and the other one goes to the temp selector under the dash. (this is what I see on kleen56's link) Clarification: My choice of terminology in the previous posts may have been confusing. The temp switch came with the radiator fans and mounts in the radiator or on the engine. I should have referred to the A/C temp switch as the thermostat switch or the temp selector. It is the on on the A/C controls or the evaporator case. Hope this answers your questions. I have a tendency to over-explain things in the interest of clarity. Let me know if anything else I said was confusing. Joe G. |
Joe
That is very clear now. I just need to locate the thermostat switch, or temp switch to wire the last black/green wire to. I will try to identify that tonight when I get back home. Thank you guys for the diagrams and explanations. This will help me and everyone else. Thanks again Kirk
| Wiring Neutral Safety Switch / EZ-Wire Kit | horvath | Electrical | 15 | 01-20-2008 12:35 PM |
| '72 Chevy Nova Electrical Issues | jvgrago | Electrical | 15 | 05-13-2007 09:19 PM |
| HELP , My Firebird is dead | IGENFIREBIRD | Electrical | 29 | 04-23-2007 03:24 PM |
| Starter switch stock to modified wiring question. | Kallie49 | Electrical | 5 | 06-23-2006 06:01 PM |
| 85 s-10 distributor wiring question | strracer7 | Electrical | 1 | 09-29-2003 03:39 AM |
