how do i wire up blinkers for my rat rod, im using a stock 89 firebird colum - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2010, 02:24 AM
n_keiser_rat's Avatar
its homemade, and its cheap!!!
i am building a really low budget rat rod. i have an 89 firebird colum with all the wires still pluged in, i just cut them from the car... im am just not sure how to wire the blinkers up so that it will work and blink, off this colum. i have 1157 bulbs in the back with sockets out of an 80 z28. break lights are on a seperate circuit. and running lights are on the dim part of the 1157 for the turn signal. is their any wireing diagrams out their for this colum or does anyone know how i can make this work??? any help is greatly appreciated... thanks nick.
Old 01-17-2010, 04:38 AM
Last journal entry: 50 Ply wagon
You need to know the color code of the wires in the column. Then you can figure out what wire goes where.
Old 01-17-2010, 06:52 AM
poncho62's Avatar
Wiki Edits: 5
I take it you are not buying a aftermarket wiring kit. If thats the case, use the fuse box from that same 89 Firebird. Get the whole harness.........The connections should just plug in under the dash, flashers and all....You will still need a diagram to figure out which wires go to the bulbs etc.
Old 01-17-2010, 11:11 AM
well i have already used a boat fuse block and wired up everything from the breaklights to the horn, i even figered out how to use the ignition switch from the 89 colum, i used a ford silinoide on the inside of the firewall so i wouldnt have any hot wires on the outside of the fire wall, so it wouldnt be so easy to hot wire if someone tried to steal it. i just need a diagram or something to work off of to figure this out. i dont have the 89 firebird anymore but if i had an idea on how to wire up the flashers out of a firebird, like a diagram on it, ill go to a salvage yard and pick up the flashers and pigtails off of one...
Old 01-17-2010, 11:22 AM
ogre's Avatar
the 'Duracell Project'
painless has manuals online for your viewing pleasure
TURN SIGNAL SECTION
GM Designation
Blk Horn
Lt.Blu LF Turn Signal
Dk.Blu RF Turn Signal
Brn Hazard Flasher
Pur Turn Flasher
Ylw LR Turn Signal
Grn RR Turn Signal
Wht Stop Lamp Switch
IGNITION SWITCH SECTION
Pur/Wht Ignition Start
Pnk Ignition Coil
Brn Accessory Fuse Panel
Orn Ignition Switched Fuse
Red* Battery B+
Red* Battery B+
power into the column is thru your flasher or the stop lite switch (which ever one is being use)
power fed to brake switch and then into column
Old 01-17-2010, 01:45 PM
Cape Cod Bob's Avatar
Link . This is a little complicated. I will try to find a link I used was very simple to follow and post. Bob http://www.hotrodders.com/forum/redi...ire-manual.pdf
Old 01-17-2010, 01:53 PM
Found it
http://www.oldengine.org/unfaq/sig3.htm
Old 01-17-2010, 10:35 PM
ok so how sould i wire up the flasher part and where should i go to get a flasher?
Old 01-18-2010, 01:23 PM
ogre's Avatar
your column is set up for 2 flashers, but you can use 1
10 amp fused wire to flasher,
tie the brn & pur together coming out of the flasher
any auto parts store will have a flasher
the only other power in is your brake lite sw
off the same fused wire hook in to the brake lite sw
and out to the wht
all the other wires go to lites lf, lr, rf, rr
and blk to horn
Old 01-18-2010, 02:29 PM
ohh ok i get it.... thanks everyonr for your help
stroke to rod ratio jacobm99 Engine 28 12-16-2013 06:46 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 04:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 10:03 PM
Rod ratio RobbieRat Engine 16 11-29-2005 07:52 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 11:06 AM
