How do my lifters look? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2008, 04:11 PM
v8hed's Avatar
AK427
Got the heads off and just wondering how my hydraulic lifters look in terms of wear? What can you gurus tell me about how my cam is doing, etc?
Thanks,
Ian.
Old 06-23-2008, 04:21 PM
What kinda mileage on the motor ,,is it a Stocker..? a mild buildup with cam,aftermarket springs..? the top lifter looks normal, the next 2 look like improper break-in, or excessive spring pressure wear.
Old 06-23-2008, 04:22 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
THe one with the brown skid mark looks weird to me. Like it is not spinning like it should in the bore.
I am no guru though.
Old 06-23-2008, 04:23 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Yeah the straight mark indicates that the lifter is not spinning on the lobe. It is too late to do anything about it though. Probably had the lash too tight.
Old 06-23-2008, 04:25 PM
v8hed's Avatar
AK427
Are you talking about the straight oil mark in pic #2?
The engine hasn't been run for a couple of weeks, if that could have any bearing on things?
Old 06-23-2008, 04:27 PM
v8hed's Avatar
AK427
6k miles on the engine. Mild build-up (Performer RPM cam, Performer RPM intake, 600cfm carb, iron heads). Not sure what springs are in the head, but they're singles with dampers.
Old 06-23-2008, 04:55 PM
FEDDO's Avatar
If you feel like you need new lifters. that would be your call. why do you have the eng back down with so few miles? lifters are cheap.
Old 06-23-2008, 04:59 PM
v8hed's Avatar
AK427
Over-heated and decided to pull the heads to get them check over (although cylinder compressions were OK). Also a good opportunity to clean and inspect as I've only recently acquired the car.
Won't be installing new lifters... lifters are cheap, but a new cam and damage caused by flattening lobes isn't. Heard too many horror stories of changing lifters without changing the cam.
So, do these lifters look 'OK'? Does my cam look in good shape judging by the wear on the lifters?
Old 06-23-2008, 05:50 PM
techinspector1's Avatar
Wiki Edits: 326
Looking at the lifter from the side while holding it straight up and down, lay the edge of a steel rule across the face where the cam lobe rides. The lifter should have a very shallow crown to it. If you can see light on the edges, they are probably still ok. If you can see no light at all or light only in the middle of the face, they're toast.
Old 06-23-2008, 06:56 PM
SSedan64's Avatar
V8hed on the #2 Pic is that a permanent stain/discoloration from heat or oil that will wipe off?
Old 06-23-2008, 06:58 PM
v8hed's Avatar
AK427
The brown marks are just oil. The lifter looks identical to that in pic #3.
Are my lifters really that bad? I really don't wanna have to change the cam if I don't absolutely have to.
Thanks,
Ian.
Old 06-23-2008, 07:22 PM
Wiki Edits: 326
Like the ad on TV says, "You can pay me now or you can pay me later". It's probably gonna cost more later because the shrapnel will take out the bearings also.
Old 06-23-2008, 07:33 PM
ericnova72's Avatar
More for Less Racer
Lifters
They are trashed, looks like improper break-in or possible light interference(spring retainer underside to top of valve guide or seal, maybe end of rocker slot to stud). Wouldn't go anywhere but the trash can if it were mine, cam is junk too. Time to completely disassemble and check the entire short block, the damage has been done. Everything is going to need a careful inspection and cleaning. Sorry it's not what you want to hear, but it was junk before you got it.
Old 06-23-2008, 07:37 PM
v8hed's Avatar
AK427
How can you tell? What is it about the lifters that tells you that?
This is very strange because the car was running great
Old 06-23-2008, 07:39 PM
n-gin's Avatar
BrraaAAAAP!
Well I just pulled the Edlbrock RPM cam out and the lifters in the Olds and the cam is wipped for sure. Actually it looks like the lifters you have. #4 Intake looks more like a speed bump then a lobe. So I say make sure the valve springs are correct cause your lifters do not look good. It actually looks like your cam is walking due to the wear pattern on the last pic.
Lifters v8hed Engine 9 06-10-2008 07:39 AM
Damage to Cam Lobes and Lifters on 454. What caused it? leejoy Engine 50 11-30-2007 07:52 AM
Hyd. Roller lifters problems hotrodf1 Engine 121 10-25-2007 02:31 PM
Roller Lifters - standard cam ckucia Engine 27 01-27-2006 02:05 PM
lifters won't stop ticking - help Litdave Engine 6 07-25-2004 12:50 AM
