Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to do a paint job start to finish
Old 03-27-2011, 06:11 PM
Bad66 Bad66 is offline
After sanding and prep, I used a featherfill which is a high build sandable primer. It basically helps fill some of the most minute spots. Hit the car with that and then long block the whole car. You may have to do it twice if you find alot of spots. Then I hit it with about 2 good coats of primer, then paint, all in my garage. Remember, if you can feel it with your hand, you will most definatly see it in the paint!!
