Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to do proper old school rivets
Old 02-07-2012, 02:31 PM
35WINDOW's Avatar
35WINDOW 35WINDOW is offline
Last journal entry: Update on my Build-Lights
If you are going to use Steel Rivets, then you have a few choices to choose from-
1. Use a Squeeze-
http://www.yardstore.com/browse.cfm/4,3898.html
2. Get a Bench Top model-
http://www.yardstore.com/browse.cfm/4,4334.html
and, don't forget to buy a Die Set for either-
http://www.yardstore.com/browse.cfm/4,6455.html
3. Buy a Rivet gun (generally, 3X is best for most things)-
http://www.yardstore.com/browse.cfm/4,6214.html
and, the Rivet Sets-
http://www.yardstore.com/browse.cfm/2,296.html
and, Bucking Bars-
http://www.yardstore.com/browse.cfm/2,412.html
It really depends on what you are doing, what kind and how far they are from the edge of the part, or where in the Car they are located.
If it's a part that you can Rivet before the install, a Hammer and Vise can do many Rivets, or a Hand Squeeze can do them faster and better, but they have limited reach.
A Rivet Gun will set about any of them, but it takes practice to understand how hard to hit them, and you don't want to be banging them in-just 3-5 hits and they should be good-it's like Welding, you mess up and learn. If you are Riveting on a car, you will probably need a helper to hold the Bucking Bar-I will generally make a few pieces, clamp them in a Vice, then have my helper watch what happens when I hit them so they can understand what to do-
I will use a Roper Whitney punch (if I can) to make the holes (better), or a drill (not as good), Cleco it together, and Squeeze or Rivet-
