How do the pros spray bulk contact cement? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-22-2007, 07:53 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
If you are going to do any gluing with spray cans, forget 3M 77 -- it will *never* hold! You have to use a high-temp glue only ... here's the one I'm using, and with good success:
Performance High-Temp Glue
  #17 (permalink)
Old 01-23-2007, 07:13 AM
DanTwoLakes's Avatar
Wiki Edits: 22
What you need is high temperature contact adhesive , that's what Performance is. In spray cans, other options are DAP Top and Trim Spray, and 3M 08090 Super Trim Adhesive. 3M 77 is an all purpose glue and not intended for high temp. applications. You are right, though, I've never had any good luck with 3m 77, no matter what I was gluing.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Removing silicone and contact cement? Gearhead forever General Rodding Tech 2 02-09-2005 07:31 AM
I'm good with a spray can.... what am i doing wrong! harrington Body - Exterior 21 04-25-2004 01:28 PM
