cheap primer gun
Well i don't know the exact product you are using but i can tell you what worked for me, i used my old high build primer gun until it needed a rebuild then i went to harbor freight and bought a $30 gun. as long as your gun has a large tip and enough air pressure you should be fine, i have yet to have a problem, solvent based adhesivescome out a little stringy no matter how the gun is set up, if you have blotches of material coming out turn up the pressure and down the amount of adhesive. good luck.
