How do remove motor mounts from frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2005, 02:07 PM
New Member
I am doing the 54 chev to s10 frame swap. I am dropping in a 350, I have to replace the motor mounts on the frame to 2.8l mounts. I have tried to remove them but there is a nut on the other end of the bolt and no way to get at it with a wrench.
Do I really have to remove the shock and spring to do this?
Old 10-12-2005, 02:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You may need to..or there is always a hot wrench
OMT
Old 10-12-2005, 03:35 PM
Almost an old guy...
If I remember right the JTR swap book suggested using a hole saw and cutting a hole so that the nut can be gotten to on the side of the frame mount. I was able to spin mine off with an impact (got lucky) and instead of replacing that bolt when the new mounts were installed I took the easy way out and welded them in place...
Old 10-12-2005, 04:57 PM
New Member
this is going to suck
Old 10-12-2005, 06:17 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
In a g-body, you have one little access hole in the front of the frame you can easily do one and maybe two if you are lucky, then you have to go between the lower control arm and the frame to get at the other two. I handed my 85 Regal off to a shop to mess with them. They are hard enough with the motor out I can't imagine doing them with the motor in. oh well I didn't have to do them and they got beat by the flat rate.
Old 10-12-2005, 07:52 PM
Oh man that sucks on GMs! I just did it on a '74 Camaro without removing the lower triangle.2 good guys,the one under with a wide assortment of 3/8" extensions,wobble sockets,ratchets,pry bar etc.Take your time,curse the engineers,drinks,snacks and luck.
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 09:46 PM
Cantilever system for air bags 53LEDSLED Suspension - Brakes - Steering 17 12-05-2004 03:26 PM
57 chevy frame alignment question... please help! Sanspants Suspension - Brakes - Steering 1 07-20-2004 10:15 AM
Body & Frame question ruiner808 General Rodding Tech 7 09-14-2003 05:54 AM
