We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 05-06-2005, 07:52 PM
gator412's Avatar
gator412 gator412 is offline
1955 2nd series Chevy Pick Up
How do remove pump pulley?
Hey guys,
I need help again. I am putting power steering on my 55 2nd Chevy pick up. I received the power steering brackets today and am now trying to remove the original brackets. One of the bolts is behind the pulley and the pulley has to come off. The shaft of the pump has a allen head. There is no nut on the end. The pump comes off a 1974 Chevy
I did a search and didn't find out how to remove this type of pulley. Looks like it screws on?
Name:  PS pump side w bolt.JPG
Size:  78.8 KB  Click image for larger version
Name:  PS pump front.JPG
Size:  88.9 KB  Click image for larger version
Name:  PS  pump back.JPG
Old 05-07-2005, 05:49 AM
adtkart adtkart is offline
adtkart@aol.com
The pulley presses on. You will need a puller to remove it. It installs back on using a bolt and washer. Basically, removing it anyother way, will destroy the pump and pulley.
Old 05-07-2005, 09:38 AM
gator412's Avatar
Thanks for the info. It look like it threaded on to me.....but that is why I asked.
Old 05-07-2005, 02:07 PM
Triaged Triaged is offline
Triaged's barnstar
Wiki editor
Last wiki edit: Crankshaft Coalition Wiki
I'll add a few things...
1) You can get loaner tools from many auto parts stores or just bring it in and do it there. They do that kind of stuff all the time.
2) Add a nut to the bolt and washer to install the pulley. Just like when you put on a harmonic damper on the front of the engine you don't want to use just a bolt to pull it on. Get a long all thread bolt and run the nut all the way onto it. Then put the washer onto the bolt and thread the bolt into the shaft. Then hold the bolt and turn the nut to press on the pulley. That way you won't strip out the threads on the shaft
Are you using a short or long water pump?
I have a short water pump and that is the pulley I found that would work after converting to the newer pressed on p/s pump.
Old 05-07-2005, 05:39 PM
adtkart@aol.com
Actually.... Most pullers come with a special bolt, washer, nut, and bearing, to install the pulley. The bearing makes installation much easier. Having someone at the parts store do it does even better than that. LOL
Old 05-07-2005, 06:28 PM
edge's Avatar
edge edge is offline
Time is short, are you ready?
You can rent the tool kit in the picture below at Autozone. If I remember correctly, it is like $30 and is refunded upon return. You will need this to do it correctly and not damage the pulley and/or pump shaft. Ed
Old 05-07-2005, 09:46 PM
gator412's Avatar
Got it done
Thanks guys for the help. I went to Kragens and rented the tool for $46 with full refund upon return. The pulley came right off, I got the bolt removed and put the pulley back on.
Old 05-26-2005, 01:06 PM
70Shorty's Avatar
70Shorty 70Shorty is offline
Bob
Hey, This is why I like posting on this sight, You ask a question and you get results. Man, thats cool !!!
Thanks Bob,,
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "How do remove pump pulley?"
pulley for p-steering pump bet on black Suspension - Brakes - Steering 1 04-08-2005 08:43 AM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
Shimming pulleys out to match water pump pulley 406chevelle Engine 8 07-02-2004 09:36 PM
Overdrive Water Pump Pulley SilverFox2 Engine 15 08-29-2003 09:03 AM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
