How to do two tone with straight edge - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-02-2005, 08:24 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Originally Posted by Bee4Me
What about shooting the black and then an inter coat clear? Yeah, another step, but that would buy a lot of time and no clear blend line.
Intercoat would work here, it has a recoat window of 12 hours for HOK... and you can usually tape it after 30-45 minutes...
I was once a fan of intercoat... A big fan, however as time has passed, and I have learned more about products in this industry, I think it is ........ not worth the money really.. i would rather thin down some clear... allot.... then spray it instead....You could do whatever you wanted to the next day with that super thin clear, and it sands much easier than intercoat, plus there is not the added cost of intercoat... Just my 2 pints worth
Matthew
  #17 (permalink)
Old 10-02-2005, 09:37 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Humm?? and the big draw back with using a clear which is cut,what,50%? would be....
I don't know myself as I've never cut any more than 20% but I'm not a big inter coat fan either. Got me to thinking anywho BK.
On this truck deal,I'd just plan on a long day and get it all on at once.
Shoot the black,mask,shoot the yellow and clear it,call it a night,color sand and clear it for good.
  #18 (permalink)
Old 10-02-2005, 10:15 PM
BK ewwwwwwww, eeeeee, that gives me the heebee jeebees. Thinning clear a lot can cause big problems. One would be that the film of clear is too thin to protect it from solvents getting thru it when the next coats are applied. Another would be that you sand thru easier and the same thing happens.
Now, you may do it all the time, your products may not be as sensitive, the base may be catalyzed and isn't as susceptible to these problems. But some systems are, so suggesting it may cause some problems for someone.
Applying two coats of clear to protect it isn't that much film build.
  #19 (permalink)
Old 10-02-2005, 10:16 PM
BondoKing's Avatar
KING OF BONDO
Jclark, has tried this, I would say at least a 50% cut of reducer, I want to say it was a 100% cut ... You wont need much, as your using sooo much reducer, the downside... I dont see any downside.... It is an over reduced clear that is not for topcoat purpose... die back is not an issue here either,and if you are using good products that becomes less of an issue.... anyways.... You are going to scuff it in the morning and tape/stripe/re coat/ whatever... Works great, not any extra cost, and you are still using the same products so there is not a compatability problem.... Jim had major issue's with the HOK intercoat lifting his dupont base... major problems.... He went to the super reduced clear and not a problem one
Matthew
  #20 (permalink)
Old 10-02-2005, 10:24 PM
Bee4Me's Avatar
OkeeDookeeDookie.
I'll give it a try. I just cleared a Tangerine Kandy panel today for some graghic practice and we'll just have a go at it.
Like you said,Just a "covering" and all it need's is a little scuff for the next round.I plan on quite a few layer's,so this will be good for the 'speriment.
  #21 (permalink)
Old 10-27-2005, 01:51 AM
truckster69's Avatar
Wow
Have you ever painted anything, cause it sounds like your way lost. You might want to start out easy black is a hard color to paint.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Painting in pieces. Can I do it? rrmccabe Body - Exterior 33 11-09-2005 08:37 AM
Sparaying the door jambs ptcamaro Body - Exterior 11 09-12-2005 11:52 PM
Need to paint a very straight black car firechicken383 Body - Exterior 15 08-22-2005 02:49 PM
Masking Door Jams etc. 36ford3window Body - Exterior 9 02-06-2005 09:17 AM
