Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do you build a trunk lid interior panel
Old 11-30-2006, 06:23 AM
Hooligan32 Hooligan32 is offline
Still have some questions
So if I use the waterboard and preshape it, I will then fit it back to the decklid trim the excess and mark locations for fasteners correct? Should I use a spring type clip and then cover the whole board in 1/8 Landau foam to cover the clips and then upholster or is there a better way to attach clips and upholster. Also when I go to upholster the piece I will need to glue the entire surface as opposed to wrapping it around without glue on the face, like you would a flat panel, right? Sorry for any confusion.
Thanks for your help
