How do you figure compression? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2005, 08:30 PM
raidmagic's Avatar
Last journal entry: Engine going back in the Hudson.
I have a 454 that is rebuilt. What I want to know is how do I figure out what the compression ratio is? I didn't build the motor I bought it redone in a truck and the guy didn't know the answer. I plan on doing head work and a cam but would like to know what I am starting with.
Thanks
Old 03-18-2005, 08:34 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
comp ratio
Pick your combo out of the list. It will give you comp ratio. SRP Pistons
Old 03-18-2005, 10:42 PM
Max Keith's Avatar
compression ratio
volumn of the cylinder, plus the volumn of the unswept area divided by the unswept area.
Unswept area: the relief from the top of the piston to the deck of the block, the combustion chamber volumn, the volumn of the valve reliefs in the pistons, and the volumn of the cylinder opening in the head gasket.
Suptract from that the volumn of the dome, if you have domed pistons.
Cylinder volumn + Unswept Area Volumn divided by the Unswept area volumn.
Volumn of the cylinder is Pi X R squared X H.
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 10:29 AM
Figure this one out willowbilly3 Electrical 7 12-25-2004 04:56 PM
how to figure out compression ratio? Trav Engine 5 08-05-2003 09:09 PM
How to figure compression ratio GearHead69 Engine 3 06-14-2003 11:13 PM
compression calculation gabledawg Engine 4 03-06-2003 03:13 PM
