How do you get the inner seal out of the speedo housing on a TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2009, 08:41 PM
Mad_Max's Avatar
I have a TH350 (Chevy trans, not BOP) and I need to replace the 2 seals on the steel housing (bullet) that holds the driven speedometer gear. My question is, how do you get the inner seal out of the housing?
Thanks
Old 04-02-2009, 09:07 PM
McLeay F1's Avatar
Last journal entry: body work
I ran into this problem a few years ago, and replaced the whole bullet with an after market unit from a trans shop. it was better made and guaranteed not to leek, think it was twenty bucks, looked billet in nature.
Old 04-02-2009, 09:13 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
read this it will help.speedometer cable leak th 350 . cole
Old 04-02-2009, 10:50 PM
Mad_Max's Avatar
Thanks... I did find that earlier but it says "it is a small lip seal held in with a small wire clip. This is removed from the outside end of the housing with a screwdriver or pick tool" I'll be darned if I can see any wire clip or any way to get the seal out. I dug a good bit of the seal out with a pick. I'm stumped.
Name:	speedo bullett.jpg
Old 04-02-2009, 11:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The after market speed-O housing with metal clad seal... pry out the seal with a screw driver.
The problem is the small rubber seal in the rebuild kits does not fit the opening... too small.
you need the metal clad seal or buy another housing unit complete like pictured.
Stupid thermostat housing gasket Aussie XAXB Engine 6 12-16-2008 09:54 PM
Munice Speedo Seal Info????? deegainey Transmission - Rearend 5 06-16-2008 11:02 AM
Replacing speedo driven gear fitting & seal assembly 39chevy Transmission - Rearend 2 09-28-2006 06:53 PM
4L60E tail housing seal leak bluesman123 Transmission - Rearend 13 01-31-2005 11:54 PM
GM Turbo 400 trans front seal housing question Gary Shugart Introduce Yourself 1 01-13-2005 03:56 PM
