How do you get the right height dimesions for the low and reverse clutch stack up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2011, 06:17 AM
old yukon's Avatar
How do you get the right height dimesions for the low and reverse clutch stack up on a 4L60e ??
I cant seem to get the right height stack up for the low and reverse clutch stack up. Both the old and new set up fall short of the 1.20 <> 1.24" dimesions for "D". Maybe I got it wrong. This is how i did it, and these are the reading i got (see below)
2 questions:
Q 1. If i add a old turbular steel uder the selective steel that sits on the wave plate, is that a problem or not?
Q 2. if I leave it as it is what would happen ?
Old 04-22-2011, 10:22 AM
tnsmith10's Avatar
when will it rain???
if it brings your clearances up to spec, then it should be fine. what im noticing here is the new frictions are quite a bit thinner than the o.e.m. frictions that came out from what i saw, and too much clearance is not good. can lead to delayed engagements, and early failure from slip.
the wave plate is a cushion so it doesnt engage forward or reverse harsh.
on the selective steel, how think is it? i didnt see anything on its thickness.
Old 04-22-2011, 10:48 AM
old yukon's Avatar
Thanks for the reply.
The pack didn't have any different selective steels. just 5 straight standard steels.
the Old steel is 0.069 bringing the height to 1.242" 0.002 over specs.
Is this 0.002 over an issue?
Is there a problem butting an old steel and new steel together on top of the wave plate?
Old 04-22-2011, 11:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are 0.049" selective steels- would bring you to 1.222"
Old 04-22-2011, 11:19 AM
extra steel
just add 1 extra steel plate on top of the wave plate that should get you 50/60 thou.clearance general rule of thumb 10 thou.per friction,oem clutch specs are always too loose no one builds them that way who does this for a living
Old 04-22-2011, 11:32 AM
old yukon's Avatar
Thanks for the suggestion Colbalt 327.
I thought a small excessive clearness would not be a real problem,as you pointed out Angila427.
still one question unanswered. Is the old and new steel together a problem or not ?
Old 04-22-2011, 11:38 AM
not a problem i do it all the time to get the clearance right
Old 04-22-2011, 12:04 PM
old yukon's Avatar
Ok so butting old and new steels together is something that is commonly done by many tranny builders to get clearances right, and there is no adverse after effect like slipping of clutches ??
There you go you learn something new everyday.
Old 04-22-2011, 12:29 PM
old yukon's Avatar
just to make sure i have made things clear.
So a stack up like this is ok.
old support assembly
new friction
new flat steel
new friction
new flat steel
new friction
new flat steel
new friction
new flat steel
new friction
new flat steel
old turbular steel
old wave plate
Old 04-22-2011, 04:23 PM
thats it good luck
Old 04-24-2011, 11:02 AM
old yukon's Avatar
I don't know what you meant by that's good luck??
Anyway, I was not to happy with the previous measurement. so I tried a few other options to try and get the best results.
I went beck to re measure the stackup, but this time i placed the waved steel second last. I then measured it two ways, with and without the waved steel. The results were not consistent with the waved steel in the stack.
Taking readings at several points around the stack up with the waved i got between 1.243 <> 1.248", 1.245" average.
Then without the waved i got 1.1145" consistently. Meaning the additional wave makes reading less accurate.
If we add the waved ( 0.095") to the second reading we get a total of 1.21" which falls with in specs.
Does this sound correct to those guys who are experienced at doing trannies for a living ?this was my stack up .
new friction
new flat steel
new friction
new flat steel
new friction
new flat steel
new friction
new flat steel
new friction
new flat steel
old wave plate
old turbular steel, obviously the last 2 with be switched on installation !
Old 04-24-2011, 12:21 PM
old yukon's Avatar
Here is yet another way buy i don't have a dial indicator, and using the verni caliper by hand in unsteady, and produces inconsistent reading.
Here you are meant to install the low and reverse clutch pack and and assembly plate, without the low reverse clutch roller and race, so that you can get the scribe in. Some use the scribe pick tool form the bottom.
Set the dial indicator on top of the assembly, and zero it. Use the scibe tool to lift the clutches to get a reading on the dial indicator. Anything from 0.50" -0.55" is good.
It might also be possible to get some feeler guages in the middle of the stack under the assembly, as another option.
Old 04-24-2011, 11:07 PM
old yukon's Avatar
Some feedback for ya all.
I tried to put the stack back in, it was so tight i could hardly get the snap ring in. I tool out the center roller race and the extra old wave plate. I reinstalled it and this time measured in form the top under the assembly plate. All measurements look fine I got 0.49" using feeler gauges in from the top measuring between the clutched underneath.
Does that sound right ????
I would appreciate some constructive reassurance here.
Thanks in advance
Which way does the low reverse roller clutch assembly go? old yukon Transmission - Rearend 6 04-22-2011 05:55 AM
removing the clutch hub of the reverse input drum old yukon Transmission - Rearend 4 02-01-2011 09:37 PM
700R4 rebuild with wider low reverse roller clutch qwkswede Transmission - Rearend 17 01-04-2010 05:29 AM
th350 int clutch height to low? sooper Transmission - Rearend 5 11-27-2009 03:33 PM
700r4 Low/Reverse Clutch Pack 123pugsy Transmission - Rearend 2 12-29-2007 08:31 AM
