Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how do you pick header gaskets for SBC
Old 12-08-2012, 05:33 PM
chucksrt chucksrt is offline
Thanks for all of the help guys! I ordered the remflex gaskets. I hope to be able to set it and forget it!!
I bought a set of proform steel roller tip rockers and I had pretty bad valvetrain noise (they were all adjusted properly) and then one decided it wanted a to take a break and cracked in half. so I ordered a replacement and found that others do not sound that good either. Now I was forced to buy another set of rockers but I went with comp cams (cost more but but should be manufactured to a higher standard I hope!!). I don't think it is worth it to try to save a buck when your building an engine! I only ever get this van running long enough to find more problems!! Most of which were due to manufacturing. I can't believe how many bad parts I got while building this.
Sorry for the rant I just was thinking about how I even got to hear the exhaust leak in the first place.
