I tried about every gasket known when I first started my current car. Most lasted a day or so..... maybe 100 miles. I even tried the aluminum ones suggested....they are still too hard.
Even the composit style failed as the bolts would never stay tight very long.
I finally got a set of solid copper ones with the embossed o-ring. It took a number of startup and cool downs to stabilize them but they now have well over 20k miles on them. The bolts stay reasonably tight. I do keep after them however. The collector gaskets are the only problem now and that is only because I have opened the pipes up a number of times to replace the starter and once to replace an oil filter.
I have had the main header gaskets off but I anneal them each time I do. Gradually the embossed o-ring will flatten out so you need to replace them if you keep removing them. Do not mix them up side for side or in and out.
I use SS bolts on the heads with lots of never-seize and standard gr 8 bolts ont he collectors ...again with never-seize. I don't like using the SS bolts but rust is more of a problem than strength.
It is a muct to have the gasket surface on the headers flat. I carefully filed mine as I did not have a large enough belt sander to do the job. I took a while and a new sharp file but it was worth it.
I have seen a stack of bellville washers under the bolt heads used as a spring but I have not tried this. I think the heat would get to the washers after a while. The idea here is to get a little compliance in the bolt tension to allow for the expansion and contraction of the bolt and head. You have to hold the bolt from turning however.
