Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how do you pick header gaskets for SBC
  #29 (permalink)
Old 12-14-2012, 11:33 AM
1971BB427's Avatar
1971BB427 1971BB427 is offline
I'd leave the locks off your locking bolts for awhile. You'll need to check them often enough that it will be a pain to remove them each time, so save them for after the gaskets have seated. The bolts don't usually work loose until the gasket seats from heating, and then the resulting slack lets them begin to loosen.
I check/tighten mine after every short drive for at least the first half dozen times, and then they should stay tight and not leak so you can install your locks.
