how do you pick header gaskets for SBC - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-27-2013, 08:19 AM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Originally Posted by packratwrecker View Post
I've always used plain, old manifold gaskets. Slather the paper side with anti-seize & lock'em down....
Should the paper side go toward the head or the header? And for those of you that are using the stock manifold gaskets do you agree with using anti-seize or is that not necessary?
Thanks,
John
  #32 (permalink)
Old 01-28-2013, 02:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks,
John
Just saw this post or I'd have answered earlier.
The foil side goes towards the header. I haven't tried using antiseize on exhaust gaskets.
The Following User Says Thank You to cobalt327 For This Useful Post:
lakeroadster (02-05-2013)
  #33 (permalink)
Old 02-05-2013, 04:38 PM
I wanted to thank cobalt327 for the advice on using stock manifold gaskets. Did the install on my '65 C10 this weekend and it worked great. Easiest header gasket swap I have ever done.
Here's the gasket set P/N's I ended up using:
Gaskets installed:
And to tighten the back two header bolts on the right side this works pretty slick:
header gaskets 69 gto Hotrodding Basics 1 03-11-2012 10:50 PM
header gaskets dwain Hotrodders' Lounge 2 09-22-2009 10:59 AM
the best header gaskets to use????? dannyessexc Engine 8 05-15-2009 04:02 PM
header gaskets markzepp820 Engine 5 12-14-2006 05:42 PM
Header Gaskets dollybud Engine 5 06-02-2003 08:38 PM
