How do You "Prepare" Sandpaper for Wet Sanding?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2011, 04:33 PM
texastomeh's Avatar
Looking for advice on how to "prepare" wet/dry sandpaper for wet sanding.
Used the SEARCH function to no avail!
Should I soak it in plain water or add a drop or two of "Dawn" or alcohol?
How long should it soak? Minutes? Hours? (Mininimum/Maximum)
Is soak time "Grit dependent"?
ANY and all advice greatly appreciated!!
THANX in advance.
Tom
Old 03-05-2011, 05:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A bit of dish liquid and a couple minutes is all I've ever done- but know now that I AM NOT qualified to advise anyone on body work procedures. Actually, I always preferred to use running water whenever I was able.
Hopefully this response will help get you some real advice.
Good luck.
Old 03-05-2011, 06:02 PM
302 Z28's Avatar
On a new sheet of paper I rub it across another sheet of new paper of the same grit. This kind of knocks off the sharp edges off a new sheet. I then have a squirt bottle of water with a few drops of Dawn dish soap added that I keep the area I'm sanding wet with.
Vince
Old 03-05-2011, 06:38 PM
Old Fool's Avatar
I try and always soak my paper for 10-15 minutes before using it. I like to use a few drops of Dawn in my sanding water mister bottle.
My uncle was a b/f man and told me to never cut my paper with a sharp blade, that I should fold it, then tear it on the crease. His theory was the sharp cut edge could cause scratching and the torn edge did not have a defined edge and as such wouldnt be as subject to causing scratches. I always have done this but to this day wonder if I should do the same to the factory cut edges
Probably doesnt make a bit of difference, but after 40 years I still do it.
Old 03-05-2011, 10:58 PM
Rag top bird's Avatar
Hot rods are still the king
I let my sand paper soak in warm water until it becomes soft in most cases 15 minutes or so
Old 03-06-2011, 09:36 PM
I wet-sand with the help of a 5 gal bucket and a sponge.
The bucket's filled about half way with water and given a
squirt of dishwashing detergent. Then I take a clean sponge
and use it to keep the panel wet, while spongeing the sanded
area clean and squeezing the sponge out often.
With new paper, I just wipe it a couple times with the wet
sponge and start sanding. Never thought about soaking the
paper, but I guess it couldn't hurt.....?
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 08:18 PM
Covering stock "plastic" door panels with "vinyl" csilva84 Interior 1 10-05-2007 07:30 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 01:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 02:13 PM
