Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do you remove the distributor gear on an HEI distributor?
Old 01-31-2012, 05:20 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Drive out the roll pin then make up or buy a gear puller and slide that gear off. You can always drill it between a couple of teeth if the gear is junk, then breaking it, but you do risk damaging the shaft that way.
Irelands child
