-   -   How do you remove the distributor gear on an HEI distributor? (http://www.hotrodders.com/forum/how-do-you-remove-distributor-gear-hei-distributor-213657.html)
against all odds 01-30-2012 10:14 PM
How do you remove the distributor gear on an HEI distributor? i know you have to remove the pin, but how?
stich626 01-31-2012 12:53 AM
punch and a hammer..
tap,tap,tap,tap it'll come out easy..
cal1320 01-31-2012 04:43 AM
There is a roll pin through the gear. If the engine is sludged up it may not be visable without cleaning it off. And as said above tap, tap, tap.
Irelands child 01-31-2012 05:20 AM
Drive out the roll pin then make up or buy a gear puller and slide that gear off. You can always drill it between a couple of teeth if the gear is junk, then breaking it, but you do risk damaging the shaft that way.
against all odds 01-31-2012 09:58 PM
Got it. Thanks. By the way, a 1/8" punch works to drive the pin out. The gear slid off no problems.
Myriad of distributor questions to follow soon.
P.S. My "dimple" on the dist gear is on the opposite side of the rotor's "tip," not on the same side of the shaft.
