Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do you stop dust/Lint/specs from showing up in light colors?
Old 06-03-2011, 02:01 PM
777funk 777funk is offline
Originally Posted by mitmaks
Do you use tack cloth right before you shoot it?
I do the following as precautions:
-Blow off the surface
-Tack it if I see any specks or lint
-Have the spray fan running (not a down draft but a plenum pulling air past the piece and out of the building)
-Wear a Kimberly Clark suit
-Sweep out the old overspray before shooting
What I don't do (maybe my problems):
-I don't remove every last speck of the previous overspray in my booth
-I don't filter the air coming into the booth
-I don't spray the place down with water before spraying
-I don't ground the workpiece or spray gun
-I don't use any anti-static preventative measures
Those are some extra measures I found when searching. Not sure how important those would be.
