Do you use tack cloth right before you shoot it?
-Blow off the surface -Tack it if I see any specks or lint -Have the spray fan running (not a down draft but a plenum pulling air past the piece and out of the building) -Wear a Kimberly Clark suit -Sweep out the old overspray before shooting What I don't do (maybe my problems): -I don't remove every last speck of the previous overspray in my booth -I don't filter the air coming into the booth -I don't spray the place down with water before spraying -I don't ground the workpiece or spray gun -I don't use any anti-static preventative measures Those are some extra measures I found when searching. Not sure how important those would be. |
Having filtered air will help a lot and tacking whole piece before painting is a must. I also usually blow air with spray gun just right before I begin to paint. That's last counter-dust measure I use.
On the SPI forum there are a couple of guys that use SPI clear on musical instruments. http://www.spiuserforum.com/showthre...ghlight=guitar |
Switch to Envirobase One Visit Clear and put down all the clear in on session eliminating time between coats for dust and debris to get caught in between coats,,,
Mutible coats is old technology |
Filtered intake air is a must and most of your trouble....also a turbo clear that dries in minutes will help a lot.it'll dry before any dust settles on the work.lightly sand out trash between coats of clear...
All great tips..but about changing up his paint,the old guitars used to be Nitrocellulose laquer,this gave gave the guitars that disinct warm classic sound that everyone is trying to reproduce..and the older the and more worn the that paint got,the better the guitar resonated and sounded beautiful..
Nitrocellulose is hard to find..you can find it but strict EPA laws on it,thats why they stopped using it on guitars and went to other more modern paints. I have a '59 cream white all original rosewood neck Strat my father bought brand new ,,still has the original tweed case too..among 3 other strats.I been thinking about building another strat,i have a 2 peice swamp ash body,and been researchin a lil where to get the nitro paint,that stuff is crazily dangerous to your health..hope your using a good fresh air respirator system... i'm thinkin some of that dust is from some leftover overspray in that lil booth over time..maybe take the time to do s thorough cleaning and maybe paint the walls and floor again to make it all freshly clean again... |
anyway, Idealy for guitar bodies like your doing especialy if your going to be doing a lot of them is to make a paint room that you don't go in and out of yet still be in control. That is mount the part inside the booth and spray will looking through a window so no air carries dirt in etc... check this link for a small booth project that was fun..
less room less air to control heat,exchaust http://www.a2zautoforums.com/showthr...6598#post36598 |
I wonder how hard it would be to automate the gun? It's basically the same pattern over and over again for what I'm doing. |
Hope to have planted a helpful seed... There are times you can get in there with it but have another switch inside so you can turn on and off the airflow of the booth fan before opening the door..
http://www.youtube.com/user/Milogara...18/IYhxsPih7JE The exhaust fan doesn't have to be on all the time. But you do need filtered air going in while the bad air is going out. Once the fog is gone turn it off. It is even off during clearing and then turned on after the last of the clear is sprayed to prevent that cloud of over spray from landing on the part(s) Last edited by milo; 06-05-2011 at 01:16 PM. Reason: posted the cool pictue |
| Electrical Alternator light on and gage showing discharging | L-82 | Electrical | 19 | 09-19-2010 03:20 PM |
| Dust specs in paint | bobyell | Body - Exterior | 4 | 10-12-2009 06:51 PM |
| stop light troubles | cougar mania | Introduce Yourself | 1 | 09-03-2006 03:13 PM |
| Bad Stop light?(brake light) | A-BodyFan | Electrical | 7 | 03-09-2006 03:19 PM |
| Stop light surging | tinindian | Engine | 2 | 02-16-2003 08:27 AM |
