How do you stuck bolts out?
I know everyone has there own way but whats yours?On my dd I just got done painting it,its a half ton 2nd gen ram&now Im doing some suspension upgrades one being the shocks&while removing the bolts on the bottom of the shocks couldnt get the bolt on either one to budge (front pair) they have a box/shackle that connect the control arm&the back is (not sure what ya call it)but one of those welded on nuts.Well the truck dosnt sit up high enough to get a breaker bar on the wrench,its been soaked with pb,heated with tons still wont budge.Im to the point now that Im gonna have to hit the hesd of the bolt with a air hammer if that dosnt work Im gonna use my cut off wheel&drill the rest out.You guys got any good tricks?
Have you ever heard of the term: "Cold enough to freeze the nuts off a steel bridge"
Loctite Freeze & Release The idea is that freezing the bolt makes it contract, which allows the penetrating fluid component to flow into the empty spaces. As far as a penetrating fluid goes, I'm a big fan of a product called "XL440" made by LubeCorp out of Calgary Alberta. See previous thread here at Hotrodders Another useful tool is a bolt extractor made by Irwin tools ![]() Spray those threads, let it sit overnight, then hit it with a 600 ft/lb 1/2" impact. They'll move, or on very rare occasion, break. The dissambly of my 1966 GMC resulted in about 4 broken fastners ... where the metal was totally fused together. One other "old-school" trick ... Parafin Wax. Heat lightly (say 250° - 300°F) then touch the wax to the bolt threads. This is sort of the opposite of the freeze and release. You want to heat the theaded component to expand it, and the wax will wick into the open spaces. Good Luck. |
I sure meant how in my title as well as get...anyway Wow thanks for all the info.Im going to look up that tool right now!
I have used this method for getting stubborn nuts and bolts out for years with great success. Tip of the day
Brian |
The best pentrating oil I've used us kroil by kano labs. We use it allthe time doing maintenancein the oil refinery. Let soak then put your wrench on the nut if you can the beat the wrench with a 4 lb beater. We do this on nuts as big as 3 inch usually as rusty as can be, most the piping and equipment we work on is been in service for at least fifty years some closer to 80. The heat and cool then beat works as well but I usually do that as a last resort.
Kris, |
My vote is for PB Blaster. The stuff is amazing.
Ill got mine out with a torch yesterday..very happy!
I can tell you from experience that those front shock bolts on a Dodge defy most anything... I tried heat, cold, PB Blaster, Kroil, 600 ft lb impact, 3/4" impact, CP air hammer.... nothing bodged them. I finally used a cut-off wheel (several in fact) and THAT finally did it.
Now the rears were a snap... go figure! |
Yeah same here I hit ot with pb,try the impact,air hammer,air ratchet,hest,Finally burnt the head of the bolt off&the flag nut with a torch&knocked the rest out.
Found this in another (current) thread and thought it might be interesting.
Can't say I've tried it yet. |
| Removing stuck exhaust manifold bolts | Torque454 | Engine | 8 | 07-17-2011 07:08 PM |
| Hex Bolts VS. 12 Point Bolts | daveh | Garage - Tools | 5 | 03-18-2010 12:18 AM |
| Bellhousing bolts and torque converter bolts torque specs | Davey3ch | Transmission - Rearend | 2 | 09-04-2009 11:05 AM |
| Stuck a-arm bolts! | 69ChevelleAddict | Suspension - Brakes - Steering | 6 | 06-04-2006 05:53 PM |
| removeing stuck bolts | 51FordDuff | Body - Exterior | 11 | 10-27-2005 12:17 PM |
