How do you tell if a crank is steel or cast - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 08:28 AM
have 327 truck motor 66 model
Old 01-15-2006, 08:37 AM
Read the number off the crank and look here:
http://www.mortec.com/cranks.htm
All small journal 327 GM cranks are steel.
Old 01-15-2006, 08:57 AM
Vortech 4.3's Avatar
jack of all trades
cast parts have a thin casting seam. where the 2 pieces of the sand mold come together.
a forged part has a thicker seam line. where the 2 halves of the stamping machine come together to hammer the forging.
Old 01-15-2006, 09:18 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
Forgings usually have their wide parting lines ground down. On a casting this is not necessary, so you will see the parting line as a raised ridge.
Old 01-15-2006, 11:30 AM
302 Z28's Avatar
I find the easiest method is visual rather than checking numbers. As mentioned the first visual is the casting or parting line. Thin for cast, wide for steel. Second is the sound. Stand it on it's flange tap it with a steel object. A flat sound is cast (or a steel crank with a crack), a sharp ringing sound is a steel crank.
Vince
Old 01-15-2006, 02:14 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Other way around I thought; a singing crank is cast. A forged crank has a thud.
Old 01-15-2006, 04:28 PM
302 Z28's Avatar
Nope.
Vince
whats the big deal with cast steel? 406 ss monte Engine 19 02-13-2005 09:31 AM
SCAT Cast cranks Mad Maggot Engine 2 02-03-2005 09:28 PM
Cast steel or Forged Crank????? brainsboy Engine 14 02-20-2004 08:53 AM
