How do you test a power valve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2005, 12:42 PM
northern85's Avatar
Any info would help. Thanks.
Old 12-30-2005, 12:49 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
A little mini vac and the proper adapter to test for the size and function.
Or suck the valve open, put your tongue against the center hole and see if the valve stays put. This is the easiest method just to make sure it is not blown.
Old 12-30-2005, 12:54 PM
northern85's Avatar
Thanks ill try it out.
Power valve gaskets? northern85 Engine 4 12-30-2005 02:02 PM
What power valve on this 173 ci. carb setup? Arns85GT Engine 11 08-24-2005 05:44 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Changed jetting, power valve...still runs terrible BrackneyC Engine 3 04-05-2003 04:52 AM
Looking for a deal on power Brake booster,with pedal&combo valve for willys Harry Hut Interior 0 04-02-2002 01:36 PM
