how do you test the TCC solenoid on the 4L60e wiring harness? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 11:06 PM
old yukon's Avatar
After testing all other solenoids and electrical components form the 4L60e, I am a bit stumped at how to test the TCC solenoid as it is attached to the wiring harness
Can it be done, and if whats the best way to do it ??
Old 02-15-2011, 01:40 AM
old yukon's Avatar
Would this work?
As the TCC solenoid is the only one physically attached to the wiring harness, i though one might me able to test across the TCC pin and 12+input, and check the resistance there (click image).
I tried it and got 24 ohms at 20degrees C.
Does that sound correct?
Its just a stab in the dark
Name:	Tcc solenoid texting.jpg
Old 02-15-2011, 10:21 PM
old yukon's Avatar
is silence a conformation that I am on the right track here ??
Any constructive feedback would be appreciated by those with experience.
you could do that or supply power and ground you should hear it click...on a rebuld I replace them anyway I usually get a new wiring harness on all my builds 40 dollar investement can keep you from gettuing a headache
Old 02-15-2011, 10:44 PM
old yukon's Avatar
Yee i also thought about those options, but i like the learning process.
Thanks man for the feedback.
Old 03-10-2011, 01:46 AM
This is how you test the lock up solenoid:
http://www.youtube.com/watch?v=rp7lz...yer_detailpage
Just curious, how did you test the EPC pressure solenoid? thanks
Old 03-10-2011, 02:15 AM
old yukon's Avatar
I ran a resistance test on all solinoids across the 2 connecting terminals. All fel in between the OEM specs range, incuding the EPC pressure solenoid.
Old 03-10-2011, 11:57 AM
Hi, where did you get the OHM resistance specs for the EPC solenoid? and the specs for the rest?
PS, were you able to see the youtube video?
Old 03-10-2011, 12:06 PM
old yukon's Avatar
i found this..
Door Solenoid wiring A/G WILLYS Electrical 3 12-03-2008 09:22 AM
Solenoid Wiring Help Needed 454 Rattler Electrical 9 10-17-2007 07:11 PM
solenoid and alternator wiring sferguson7 Electrical 3 05-21-2007 11:12 PM
ford solenoid wiring krustyou812 Introduce Yourself 1 09-21-2004 11:10 PM
solenoid wiring street rodder 1937 Electrical 2 09-14-2003 10:35 PM
