How do you upholster a hole or inside an ellipse? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2010, 05:36 PM
It doesn't seem physically possible to me, but I thought I'd ask.
Given 1/4" foam under vinyl, how would you upholster a hole or the inside of a long ellipse without some kind of trim?
If it can't be done without trim, what kind of trim is used?
Thanks
Old 09-04-2010, 07:36 PM
cboy's Avatar
Last journal entry: Finished
See following post.
Always learning...and sharing what I've learned.
Old 09-04-2010, 07:40 PM
cboy's Avatar
This may not be what you have in mind, but might give you some ideas. These ellipses are on my door panels and the center insert is 1/8" aluminum. The graphic is a vinyl decal. You can view more pics and detail in my journal starting here.
Old 09-05-2010, 07:25 AM
Awesome!
That may just do the trick.
Thank you very much!
Vortec pushrod hole mod david ahluwalia Engine 4 02-25-2009 12:21 AM
Crankshaft threaded hole DEPTH Lone Jack Larry Engine 2 02-08-2009 02:54 PM
Accessory hole screw up justdig Engine 2 09-24-2008 09:12 PM
Ford 390 (piston in the hole) goatman-68 Engine 7 01-13-2003 06:31 PM
dowel pin hole in crank ? HQ Pete Engine 1 04-28-2002 10:04 AM
