Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how does this air compressor piping diagram look
Old 09-01-2004, 01:37 PM
lanierledford lanierledford is offline
Marcel
Last journal entry: Choo-choo town
water
Hi humidity causes a lot of condensation in air compressors.If you're getting water at the tool hookup, you need a bigger dryer or another dryer. Air pressure drop from high to low causes condensation. maybe a pressure regular at the tank to hose connection would help. It sounds like you're just using more air than the dyer can handle. Does it have a bleed valve on the bottom of the dryer, if so you may need to leave it open a little to allow the water to bleed of as it is collected. What about the tank bleed, does it need draining. You could try building a catch tank from a 4 in. pipe about 2ft. long. Weld the ends, on the side at one end, weld a 3/8 pipe nipple, on the other end, 180 degrees from the first nipple weld another. Then drill through the nipples with a 5/16 drill. Hook the inlet air to the bottom, and outlet to the top. Sorry, you'll need and 1/4 nipple on the end which will be the bottom to drain it. You can use a drain **** ( like a radiator or a valve. The bigger and longer the pipe, the better it works cause the air has longer to stay so the water has longer to fall out. I put legs on mine, stool it up, its five ft. tall, 8 in. diam. lol
